How To Avoid Spark Explosions
Using proper static grounding devices is paramount to safety.
Spark explosions are a significant hazard in various industrial settings, often resulting from igniting flammable gases, vapors, dust, or fibers. These explosions can lead to substantial property damage, injuries, and, in the worst cases, death. The most common industrial processes prone to spark explosions include mining, chemical manufacturing, grain handling, pharmaceuticals, and any operation involving combustible materials. However, the risks are not always as obvious.
The silent culprit: understanding static electricity
Static electricity refers to the build-up of an electric charge on the surface of objects. These occur when two materials come into contact and then separate, causing electrons to transfer from one material to another. The material that gains electrons becomes negatively charged, while the one that loses electrons becomes positively charged. This imbalance of charges creates static electricity.
In work environments, static electricity can accumulate through friction between materials, such as when liquids flow through pipes or operating machinery. Static electricity can accumulate in seemingly innocuous places, such as storage tanks, conveyor belts, and even on personnel. When this static charge builds up to a certain level and discharges, it can ignite flammable substances in the surrounding environment, leading to explosions.
In 2021, the U.S. Bureau of Labor Statistics recorded 76 fatalities due to fires and explosions.
The role of dust in spark explosions
While fire hazards may be obvious when working with flammable chemicals and materials, combustible dust can be trickier to mitigate. Industries such as grain processing, woodworking, and metal grinding can be particularly vulnerable. Dust can accumulate on surfaces, in vents, and around equipment, creating an explosive atmosphere. When these dust particles are exposed to an ignition source, such as electrostatic sparks, they can lead to a dust explosion.
In 2017, a dust explosion at a milling facility in Wisconsin resulted in five fatalities and 14 injuries. The explosion also caused multiple buildings to collapse.
The importance of static grounding
Grounding creates a direct physical connection between electrical equipment or conductive surfaces and the earth. This critical safety measure provides a safe path for static electricity to flow from the equipment or surface to the earth, preventing build-up that could cause a spark. Grounding ensures that all conductive parts of a system have the same electrical potential, reducing the risk of static discharge between different parts.
The Occupational Safety and Health Administration (OSHA) and the National Fire Protection Association (NFPA) provide guidelines to prevent explosions and mitigate their effects. These include grounding and bonding practices to ensure a safe working environment.
Protecting workers with static grounding equipment
Proper grounding protects workers from electric shocks and static discharge, which can cause burns, injuries, or even fatalities. Static discharge can also damage sensitive electronic components and systems, potentially leading to workplace hazards. Here are some essential grounding equipment to consider:
1. Grounding clamps
Grounding clamps connect equipment to a grounding point, ensuring that any static charge is safely dissipated. They are versatile equipment for grounding small containers, drums, totes, machinery, or personnel in areas containing flammable liquids and dust. They come in various sizes and styles to fit different applications. Look for clamps made of conductive materials with design features that provide an effective grounding path.
2. Grounding cables and reels
Grounding cables and reels connect grounding clamps to a grounding rod or point. Retractable or coiled grounding cables with clamps are ideal for applications where equipment is frequently moved. They ensure continuous grounding during operations without causing tripping hazards.
For comprehensive protection, we recommend getting grounding assemblies and sets that include cables, clamps, heads, adapters, and connectors.
3. Personal grounding gear
Workers should use personal grounding gear, such as wrist straps and conductive footwear, to prevent static buildup on their bodies. These types of personal protective equipment (PPE) help safely dissipate any static charge to the ground. For optimal protection, use these in conjunction with grounding mats and flooring.
4. Explosion-proof lighting
Explosion-proof lighting and fixtures are designed to operate safely in environments where flammable gases, vapors, dust, or fibers introduce the risk of explosions. These lights are engineered to prevent the ignition of these substances, ensuring that sparks, high temperatures, or electrical faults do not lead to serious workplace incidents.
Explosion-proof lighting and fixtures are designed for specific hazardous environments and certified accordingly. For example, Class I Division 1 lights are intended for areas with continuous exposure to flammable gases. They also have temperature ratings to prevent overheating and potential ignition.
5. Grounding testers
Grounding testers are specialized devices used to measure the effectiveness of grounding systems in electrical installations. These testers help ensure that electrical systems are properly grounded.
The specific type of grounding equipment needed depends on your applications and the potential hazards involved. For guidance on selecting the appropriate grounding measures, devices, and gear, you may refer to OSHA 29 CFR 1910.106 and the NFPA 70.
Rick Pedley
Rick Pedley, PK Safety’s president and CEO, joined the family business in 1979. PK Safety, a supplier of occupational safety and personal protective equipment, has been operating since 1947 and takes OSHA, ANSI, PPE, and CSA work safety equipment seriously. For more information, visit www.pksafety.com.
