© Arnel Manalang | Dreamstime.com
Dreamstime M 37439411 6109524ec92de
Protect Yourself from Unsafe Acts
Aug. 3, 2021
Tips to protect yourself
Many people believe unsafe conditions are the primary threat to worker safety. While these must be dealt with, OSHA’s incident data show unsafe acts are the primary threat to worker safety.
You have direct control over your unsafe acts:
  • Think before doing. Is the way you intend to do this safe? How do you know that?
  • Be alert while dong. Are you engaging in needless risk?
  • Think after doing. Could you have performed that task more safely?
You also have some control over the unsafe acts of others. For example:
  • You’re on a ladder and Fred climbs it to hand you a tool. Tell Fred to get off the ladder.
  • You just locked out a breaker and Jason hangs his tag on your lock. Remove Jason’s tag, put your lock on a hasp, and explain LOTO procedure to Jason.
  • While you are taking voltage measurements, a product supervisor starts talking to you. Stop work, explain that you are exposed to energized circuits; resume work only after the supervisor stops distracting you.
