If you’re working for an electrical contractor that was hired to install a panelboard, consider how safe the job site is. Resolve these unsafe conditions before beginning work:
- Poor access for equipment delivery. Confirm there is an adequate route from the back of the delivery truck to the building entry, through the plant, and to the installation site. For example, eliminate the possibility of unloading a big panel from the truck onto a muddy surface.
- Insufficient equipment for transport and setup. Don’t try to “make do” with whatever is available. Determine what you need and guarantee you have it on delivery day.
- No operations window. It’s likely that part of the delivery route will need to be shut down and/or a shutdown will be needed around the installation area. Make sure this is scheduled.
- Poor lighting. To lessen the risk of crushed fingers or other injuries, take the time to ensure the area is properly illuminated.
