© Tapio Salmela | Dreamstime.com
Overloaded Electrical Strip Dreamstime Xl 113838480 5eb56d40c57c8
NFPA, ESFI Stress Importance of Electrical Safety
May 8, 2020
May is National Electrical Safety Month
Electricity helps make our lives easier, but its potential for shock and fire-related hazards are often taken for granted. The National Fire Protection Association (NFPA) actively supports National Electrical Safety Month, an annual campaign sponsored by Electrical Safety Foundation International (ESFI), which raises awareness of potential home electrical hazards, the importance of electrical fire safety, and the safety of electrical and non-electrical workers, each May.
“Computers, kitchen appliances, heaters, fans, air conditioners any equipment powered by electricity has the potential to be involved in an electrical fire,” says Lorraine Carli, NFPA’s vice president of Outreach and Advocacy. “In our current environment, amid this coronavirus pandemic, thousands of working professionals and students have left their offices and classrooms to continue their work from home. This means more family members are now online, watching television, and using appliances all at once, and for longer periods of time.”
The good news, says Carli, is that people can take simple steps to greatly reduce electrical hazards like learning the proper way to plug in appliances, safeguarding electrical outlets in the home, and more. To help address this issue, NFPA and ESFI ask residents to adhere to the following safety tips:
  • Check electrical cords to make sure they are not running across doorways or under carpets where they can get damaged.
  • Never put more than one plug in each receptacle. An outlet may have one or more receptacles – one to receive each plug.
  • Use light bulbs that match the recommended wattage in a lamp or other light fixture. Check the sticker on the lamp to determine the maximum wattage light bulb to use.
Residents should also have all electrical work done by a qualified electrician, including scheduling electrical inspections when buying or remodeling a home. Even during this time of social distancing, electricians are still working and considered essential businesses in every state that has issued a shelter-in-place order. It is critical that residents call the utility company or a qualified electrician immediately if they experience any of the following:
Frequent problems with blowing fuses or tripping circuit breakers
  • A tingling feeling when touching an electrical appliance
  • Discolored or warm wall outlets
  • A burning or rubbery smell coming from an appliance
  • Flickering or dimming lights
  • Sparks from an outlet
According to NFPA and ESFI, contact with electricity is a leading cause of workplace injuries and fatalities. During National Electrical Safety Month, electrical and non-electrical workers are encouraged to participate in safety training programs that focus on personal protective equipment, safe work practices, and risk assessments to help avoid electrical injuries, deaths, and OSHA violations, as outlined in NFPA 70, National Electrical Code (NEC) and NFPA 70E, Standard for Electrical Safety in the Workplace.
For additional tips and resources including infographics, fact sheets, and videos about electrical fire safety, visit NFPA’s electrical safety webpage.
Information about electrical codes and standards, and worker safety training, can be found on NFPA’s electrical solutions webpage.
For information on NFPA’s response to the coronavirus, click here.
