Kwik-Fit Compression EMT features an integrated steel compression coupling that, according to the company, reduces installation time and eliminates the need to purchase and store separate couplings. The Flo-Coat hot galvanizing process protects the conduit with a triple-sealed compatible organic layer to inhibit white rust and increase corrosion resistance. In addition, the product’s interior is protected with E-Z Pull interior coating for enhanced wire pulling with reduced static friction. It also meets the requirements of Sec. 300.22 of the NEC as well as UL Standard 797 and ANSI Standard C80.3.
Allied Electrical Group
For more information, visit www.alliedeg.com.
Latest from Product of the Year
