Conduit Bodies Smart LB conduit bodies are designed for use with die-cast aluminum and PVC conduit and fittings. The die-cast aluminum model features a gray powder-coat finish and is suitable for use with liquidtight, EMT, IMC, or rigid metallic conduit ...
Conduit Bodies
Smart LB conduit bodies are designed for use with die-cast aluminum and PVC conduit and fittings. The die-cast aluminum model features a gray powder-coat finish and is suitable for use with liquidtight, EMT, IMC, or rigid metallic conduit and fittings. The PVC model is for use with Schedule 40 and 80 rigid PVC, PVC flex duct, PVC general-purpose duct, PVC riser duct, Type NM liquidtight conduit, and rigid nonmetallic power and communications duct.
Smart Pathways
