Category: Wire & Cable Tear-resistant Romex SIMpull nonmetallic Type NM-B cable features a jacket system that reduces friction, eliminates greasy residue, and cuts the amount of force required to pull the cable through wooden joists and rafters and ...
Category: Wire & Cable Tear-resistant Romex SIMpull nonmetallic Type NM-B cable features a jacket system that reduces friction, eliminates greasy residue, and cuts the amount of force required to pull the cable through wooden joists and rafters and around corners. The cable’s design allows it to strip faster and reduces burn-through when it’s pulled across previously installed cables. It meets all the requirements of the UL 719 Nonmetallic-Sheathed Cables standard. Southwire
