Category: Connectors & Terminating Devices he cable entry ports in GelPort submersible secondary connectors are filled with PowerGel sealant that instantly encapsulates cables and protects them against moisture. Combining the properties of a liquid and ...
Category: Connectors & Terminating Devices he cable entry ports in GelPort submersible secondary connectors are filled with PowerGel sealant that instantly encapsulates cables and protects them against moisture. Combining the properties of a liquid and a solid, the gel conforms to surfaces yet holds its shape during handling. It can withstand –40°C to 95°C temperatures, and it’s compatible with solid dielectric cable insulation. Tyco Electronics
