The Roto-Split RS-101AC cutter features a clamping system that automatically adjusts to different cable diameters. To use, squeeze the bottom lever and cable from 14-2 to 10-4 or 3/8-in. Flex is secured with no adjustment needed. The cutter also has a depth of cut adjustment lever that switches between standard MC and new brands of reduced diameter MC cable.
