Cooper B-Line C-Port Rooftop Supports
Feb. 9, 2005
Category: Fasteners, Hangers & Accessories Made from 100% recycled rubber, C-Port rooftop support components can hold as much as 2,500 lb. The supports extend roof life, dampen vibrations, and can be used without supplemental rubber pads. Although ...
Made from 100% recycled rubber, C-Port rooftop support components can hold as much as 2,500 lb. The supports extend roof life, dampen vibrations, and can be used without supplemental rubber pads. Although they’re approved for use as rooftop conduit supports, they can also be used in underfloor applications.
Cooper B-Line
