Cooper Crouse-Hinds Space-Saver EMT Connectors
Feb. 9, 2005
Category: Conduit and Cable Fittings The male threads are located on the locknut of the Space-Saver EMT connector to increase maximum usable space inside the box. The locknuts are also designed with angled teeth to bite into the enclosure and prevent ...
The male threads are located on the locknut of the Space-Saver EMT connector to increase maximum usable space inside the box. The locknuts are also designed with angled teeth to bite into the enclosure and prevent vibration-induced loosening, and a smooth pulling surface eliminates cable stripping. The connectors are available in 1/2-, 3/4-, and 1-in. sizes in set-screw and compression styles.
Cooper-Crouse Hinds
