Category: Motors, Drives & Motor Controls Strong enough for rugged conveyor use and efficient enough to gain the NEMA Premium seal of approval, Super-E brake motors are designed to provide 20:1 constant torque speed range when used with an adjustable ...
Category: Motors, Drives & Motor Controls Strong enough for rugged conveyor use and efficient enough to gain the NEMA Premium seal of approval, Super-E brake motors are designed to provide 20:1 constant torque speed range when used with an adjustable speed drive. Rated at 230/460V, 1-30 hp, and 1,780 rpm, the brake motors are inverter-ready with inverter spike-resistant magnet wire. A washdown model is also available for areas frequently subjected to high-pressure cleaning fluids. Baldor
