Ideal Industries Inc. Industrial Clamp Meters with TightSight Display
Feb. 9, 2005
Category: Portable Test & Measurement Equipment The 700 series of 600A and 1,000A industrial clamp meters feature a TightSight display at the bottom of the unit that allows users to view readings in dark, bright, or tight locations. The clamp meters ...
The 700 series of 600A and 1,000A industrial clamp meters feature a TightSight display at the bottom of the unit that allows users to view readings in dark, bright, or tight locations. The clamp meters have audible and visual high-voltage indication over 30VAC/DC on all functions, and they’re CAT IV-600V and CAT III-1,000V rated. They also feature a one-touch backlight button for green display illumination, tapered jaws with hook tip for wire separation in tight locations, and a data hold button and offset thumb wheel for one-handed operation.
Ideal Industries
