Pyramex has released four lightweight over-the-spectacle protective eyewear options that are ANSI-rated and impact tested. The OTS model weighs 33 grams and features black adjustable nylon temples and a single lens that encapsulates the eye for enhanced protection. It also has scratch-resistant polycarbonate lenses that provide 99% UVA/B/C protection. Designed to fit over frames up to 5⅜ in. wide × 1¾ in. high, they come in clear, clear H2X AF, gray, amber, and I/O mirror variations. The OTS XL is approximately 9% larger than the OTS model and fits over frames up to 55/16 in. wide × 15/16 in. high H. It weighs 34 grams and is available in clear, clear H2X AF, gray and I/O mirror. The Cappture and Cappture Plus models are dielectric non-conductive frames and contain zero metal parts to reduce the risk of injury in the case of electrical exposure. Made entirely from polycarbonate and nylon, the temples extend from the brow bar to avoid interference with prescription frame temples. Cappture is available in clear H2X AF, gray H2X AF, amber H2X AF, and infinity blue H2X AF. Cappture Plus comes in clear H2MAX AF and gray H2MAX AF.
For more information, visit www.pyramexsafety.com.
