A new version of the CoBolt S compact bolt cutter from KNIPEX Tools features a special blade recess (71 31 160 and 71 31 160 SBA), which is designed for cutting thicker materials. Despite its compact 6¼-in. length, the CoBolt S provides high cutting power, cutting bolts, nails, and rivets up to 11/64 in. in diameter. In addition to its compact design, the cutter has a slim head designed for better access to confined areas. According to the company, the product has a strong lever action mechanism that allows the user to exert less effort when using the cutter. Below the joint is a gripping surface for pulling wires with a diameter from 3/64 in. Other features include laser-cut edges on the blades, which prevent material being cut from slipping.
