The 1597DIN family of UL94-V0 flame-retardant plastic enclosures from Hammond Manufacturing is designed for mounting to standard IEC/EN 60715 35-mm DIN rails. The family consists initially of four sizes: 2, 4, 6, and 9 standard 0.69-in. (17.5-mm) module widths. All sizes feature two mounting positions for the terminal blocks. In addition, the product includes two horizontal PCB mounting slots in the body and two stand-offs in the base for component or PCB mounting. Plain, vented, knock out, and slotted terminal covers are supplied separately and can be mixed and matched in the bodies. Primarily designed to accept PCBs is a slimline 0.91-in. × 4.65 in. × and 3.54 in. high polycarbonate control box with ventilated sides and a shaped front panel. All units feature simple no-tool snap together assembly and correspondingly easy disassembly for access to the internal components or PCB when required.
For more information, visit Hammond Manufacturing.
