Designed to test HDMI and Mini HDMI cables, the HDMI-100 cable tester from Jonard Tools is ideal for evaluating HDMI cables that may have shorts, open circuits, or wire pairs in the wrong order. According to the company, this product is designed for use on 1.2V, 1.3V, 1.4V, 2.0V HDMI or Mini HDMI cables. The unit’s “scan mode” allows you to see each individual connection being tested, and “full display mode” shows all of the tested connections at once. A remote can be detached from the main unit, allowing you to test HDMI cables that are installed or very long. An auto-shutdown function after 10 minutes helps preserve battery life, and a 9V battery (required for operation) is included with the device.
For more information, visit www.jonard.com.
