BaseTek’s Zanite Plus polymer composite pads can be custom designed to raise cabinets and enclosures off the floor or ground to protect equipment from moisture and allow for easy access. Stainless steel threaded holes can be cast to location, providing a noncorrosive, nonconductive mounting pad for equipment. Internal reinforcement can also be added for seismic pad applications. According to the company, benefits of the product include: 18,000 psi compressive strength, vibration damping over concrete, no forming and mixing concrete on-site or waiting for concrete to cure, temperature limits of -20˚F to 200˚F, water absorption of 0.01%, and internal FRP reinforcement. The units are cast to order and designed to match existing footprints and obstacles (solid or widow openings for bottom-feed options).
For more information, visit www.basetek.com.
