These metal solar placards are made with a special process that seals metallic particles under a clear anodized layer, which results in markings that have been tested and rated to last up to 25 years in outdoor use, even in direct sunlight. The placards are designed to meet the 2014 National Electrical Code), with pre-printed warning, caution and variable data messaging that conforms to Article 690, as well as ANSI guidelines. Available in packs of five with retail header cards, the products come in pre-printed and variable data versions for displaying installation-specific information, such as voltage ratings.
HellermannTyton
