Designed for the company’s Dual Cabinet Cooler systems
Suitable for NEMA 4, 4X, and 12 environments
Digital LED readout
The digital Electronic Temperature Control (ETC) is designed for the company’s Dual Cabinet Cooler systems installed on large or high heat load enclosures. The ETC accurately maintains a constant temperature in the electrical enclosure that is slightly under the maximum rating of the electronics. A digital LED readout displays the temperature of the electrical enclosure (F or C), then displays the user temperature setting when pressing the “push to set” button. When that setting is exceeded, the Cabinet Cooler system is activated. In addition, the product is suitable for NEMA 4, 4X, and 12 environments
