Zero-turn radius
Designed for working heights up to 16 ft
22-in.-wide × 37-in.-long platform
The push-around HB-P1027 low-level scissor lift features a zero-turn radius and is designed for working heights up to 16 ft. Featuring a platform that is 22 in. wide and 37 in. long, the ANSI/CSA-compliant product can lift as much as 550 lb. Weighing 870 lb, the lift’s wheels help distribute its weight and provide wheel loads as low as 250.3 psi, enabling users maneuver the lift over fragile flooring with minimal risk for damage. Other features include a hydraulic system that is completely self-contained and has only two connection points, and an entry height of only 27.8 in.
