Produces a 1-in.-wide airstream with a blowing force of 16 oz
Fits in tight spaces
Type 316 stainless steel construction
The High Power Stainless Steel Flat Super Air Nozzle produces a 1-in.-wide airstream with a blowing force of 16 oz when mounted 12 in. from the target. Designed to fit in tight spaces, the nozzle features Type 316 stainless steel construction, making it suitable for use in corrosive, high temperature, food, pharmaceutical, and chemical environments. Offering a sound level of 82 dBA and air consumption of 17.5 SCFM (495 SLPM) at 80 PSIG, the product meets OSHA dead end pressure standard CFR 1910.242(b), meets OSHA noise exposure standard 29 CFR 1910.95(a), and it is CE compliant. Force and flow are easily adjusted by installing different shim thicknesses.
