Nora Lighting LED tape light channels
Jan. 16, 2015
Can be recessed or surface-mounted Available in 4-ft lengths Constructed from aluminum
LED tape light channels can be recessed or surface-mounted in interior walls, hallways, and stairways or within railings and ceilings. The luminaires can also be mounted under cabinets. Available in 4-ft lengths, which can be joined for longer runs, six models are offered with various channel depths, including a corner model. In additional, they are constructed from aluminum and include end caps and a white diffuser panel to soften the LED lighting effect.
Nora Lighting
