Legrand Pass Seymour SelfTest GFCI with SafeLock Protection
Self-test GFCI
Dec. 31, 2014
Tests itself every 3 sec Automatic shutter system helps prevent improper insertion of foreign objects Available in 15A/125V or 20A/125V duplex models
The Pass & Seymour Self-Test GFCI with SafeLock Protection tests itself every 3 sec. If the device fails the test, a red flashing indicator light signals that it is time to replace the device. The SafeLock Protection feature automatically disconnects power to the receptacle if it detects that critical components are damaged and protection is lost. In addition, the GFCI features an automatic shutter system that helps prevent the improper insertion of foreign objects. Other highlights include an auto-ground clip and a ground screw with a back wire clamp. Available in 15A/125V or 20A/125V duplex models, both versions include dual-direction test and reset buttons. Colors include: ivory, black, nickel, antique brass, dark bronze, light almond, white, red, brown, and gray.
Legrand
