Offered in ½ in. to 2 in. trade sizes
Constructed of die-cast zinc
Can be used when transitioning between solar arrays and inverters
The 4360-DC Raintight EMT to Liquidtight transition couplings line now includes sizes from ½ in. to 2 in. in die-cast zinc. Designed to eliminate the need to assemble multiple fittings or mount a box to transition between raceways, the cULus-listed fittings are suitable for connecting to HVAC systems, generators, transformers, and other rooftop equipment. In addition, the products can be used when transitioning between solar arrays and inverters.
