Rotating tip holds rounded edges up to 2 in. in diameter
360° hooking capability
Double-sided, high-visibility blade
The GripLine tape measure features a rotating tip that holds rounded edges up to 2 in. in diameter, including metal conduit, rebar, PVC, and black iron pipe. A slotted groove in the pivoting head allows the oversized 13/8-in. tip to slide seamlessly toward an object. The tip also offers 360° hooking capability. Additional features include a double-sided, high-visibility blade; two magnets; and a lever action belt hook.
