Burndy RHCC4CUAL cable cutter
Cable cutter
Oct. 17, 2014
Cuts copper and aluminum cables up to 4 in. in diameter Scissor-action cutting blades for mid-span cuts 360° swivel hose fitting
The RHCC4CUAL is designed to cut copper and aluminum cables up to 4 in. in diameter. The remote head cutting tool features high-strength hardened steel, scissor-action cutting blades for mid-span cuts, and a 360° swivel hose fitting for ease of use in confined spaces. In addition, the cutter comes with a durable canvas carry bag and includes a 5-yr limited warranty (excluding blades). Replacement blades are available and sold separately.
Burndy
