Fluke 830 laser shaft alignment tool
Laser shaft alignment tool
Oct. 3, 2014
Designed to perform complicated alignment calculations All-in-One result screen shows coupling results and feet corrections Single laser precision alignment system
The 830 laser shaft alignment tool is designed to perform complicated alignment calculations. An enhanced user interface provides easy-to-understand results that don't require extensive alignment knowledge, while the All-in-One result screen shows both coupling results and feet corrections (vertical and horizontal) in real terms. In addition, the tool uses a single laser precision alignment system that provides accurate and repeatable measurement results.
Fluke
For more information, visit the product page.
