Designed for use with jacketed Teck cable with aluminum or steel armor
40 mil gray PVC exterior coating for corrosion resistance
Stainless steel copper-plated spring
The Teck Series of armored cable fittings is designed for use with jacketed Teck cable with aluminum or steel armor. Featuring a 40 mil gray PVC exterior coating for corrosion resistance, highlights include a stainless steel copper-plated spring that provides grounding continuity of cable armor, watertight seal on outer sheath of cable, standard neoprene seal suitable for use in operating temperatures -25° to 60°C, and an integral O-ring seal on entry threads. In addition, the product is CSA Certified Class II, Div. 1 and 2, Groups E, F, G; Class III – CSA File LR13046
