Designed for connecting cables in parallel or cross configurations
Accepts one or two wires of wire range No. 6 solid to 4/0 stranded
cULus-listed for use with rebar sizes No. 7 to No. 12
The GXP1828RF Super-Clamp is a multifunctional, range-taking grounding connector for connecting cables in parallel or cross configurations. The tool is cULus-listed for use with rebar sizes No. 7 to No. 12 (7/8 in. to 1½ in. diameter). The connector can accept one or two wires of wire range No. 6 solid to 4/0 stranded. In addition, the product can be used on round or square pedestals (round: 7/8 in. to 2 in.; square: ¾ in. to 1½ in.) in the parallel or cross grid patterns.
