HD Electric 3phase cable identifier
3-phase cable identifier
June 4, 2014
Identifies correct phases on long lengths of de-energized and discharged overhead and underground cables Includes a sender and receiver to be handheld with or without gloves Tests up to a mile of cable
The 3ID 3-phase cable identifier pinpoints the correct phases on long lengths of de-energized and discharged overhead and underground cables. The tool includes a sender and receiver designed to be handheld with or without gloves. Because of its higher test voltage, the identifier can test up to a mile of cable. LEDs on both units indicate that the cable identifiers are connected to the same phases on each end of a cable.
HD Electric Co.
For more information, visit www.hdelectriccompany.com.
