Pre-wired
NEMA 4 or NEMA 4X rating
Eliminates need for control transformer
The AcuPanel 9100 Series pre-wired panel enclosure provides a plug-and-play energy metering solution. Designed for Acuvim II and Acuvim-L Series multifunction power and energy meters, the panel features: a NEMA 4 or NEMA 4X rating; pre-wired meter; pre-mounted and wired parts, including fuses, shorting, and terminal blocks; and pluggable pre-cut holes for wires to be fed through. In addition, the unit offers simple grounding inside the enclosure and eliminates the need for a control transformer.
