DeWalt DCS371 20V MAX band saw
Band saw
Feb. 27, 2014
Weighs 9.4 lb and measures 15 in. long LED work light with 20-sec delay Ergonomic, soft grip back handle
The DCS371 20V MAX* band saw weighs 9.4 lb (with battery) and measures 15 in. long. Designed to cut conduit, rigid pipe, Uni-Strut, threaded rod, or other materials up to 2½ in. in diameter, the saw’s battery and motor are located on opposite ends of the tool, allowing it help users make a straight cut. Features include: an LED work light with 20-sec delay; a hang hook; a blade tracking adjustment to prolong the life of the blade; an ergonomic, soft grip back handle; a tool-free blade changing lever that loosens blade tension for easy blade changes; and dual bearing blade guide rollers that provide durability in the blade support system.
DeWalt
For more information, visit www.dewalt.com.
