Feature directional angled teeth
Type NWC nylon clips come with and without cable ties
Type SSWC stainless steel clips offered in four cable diameters
These wire management clips are designed to fasten onto a thin metal edge to hold cables or wires in place. The clips feature directional angled teeth that spread apart as the clip is pushed onto the metal edge and bite into the metal surface. Type NWC nylon clips are available with and without cable ties and offer different orientations for securing the cable ties. Type SSWC stainless steel clips are available with four unique maximum cable diameters.
