DualLite EVE Series LED exit sign
LED emergency luminaire
Nov. 22, 2013
100,000+-hr life 90 minutes of emergency exit illumination Accepts 120/277VAC input at 60Hz
The EVE Series emergency luminaire provides illumination using red or green LEDs rated at more than 100,000 hr. The luminaire features a NiMH battery that provides 90 min of emergency exit illumination in the event of a power failure, while a low-voltage battery disconnect (LVD) protects the battery during prolonged outages. The product accepts 120/277VAC input at 60Hz and optional 220VAC to 240VAC input at 50Hz or 60 HZ with a self-diagnostics option. Other features include a constant current charger, an external push-to-test switch and AC-on indicator that allow manual testing at any time, and pre-stripped AC input leads. With an operating temperature range of 20°C to 30°C, the luminaire offers wall, ceiling, or end mounting, and is NFPA 101 and NFPA 70 certified.
Dual-Lite
For more information, visit www.dual-lite.com.
