Using split bolt technology, this bulkhead ground connector incorporates a male Servit Post and female Servit Post as part of an easy-to-use kit.
This bulkhead ground connector allows ground wires to be connected from the inside of an enclosure to the outside. Using split bolt technology, the connector incorporates a male Servit Post and female Servit Post as part of an easy-to-use kit. The male and female Servit portions are made of silicon bronze, and the hardware supplied is stainless steel. Additionally, an optional rubber grommet is provided to ensure a NEMA 4X rating when installed correctly.
