The 30kW 3-Port Hybrid Converter is designed to reduce the costs and improve the efficiency of systems that integrate photovoltaic (PV), grid-storage, and electric vehicle (EV) charging. The converter includes three bi-directional ports, one AC grid port, and two independent DC ports — either of which can be used for PV, battery storage, or EVs. The system is designed to allow power to flow in any mix among any ports with 96.5% estimated CEC efficiency. Weighing approximately 125 lb, the product provides a power density (Watt/lbs) that the company believes is 10 times higher than other hybrid power converters.
Ideal Power Converters
For more information, visit www.IdealPowerConverters.com.
Share your thoughts about this product through the commenting box below.
