Combination couplings create transitions between liquidtight flexible metallic conduit and rigid steel conduit
Combination couplings for transitioning between liquidtight flexible metallic
conduit (LFMC) and rigid steel conduit. This line of transition fittings features NPSM threads on hub and malleable iron body with steel ferrule. Suitable for use in wet locations and concrete tight.
