SureCrimp copper compression connectors now include long blank
tang configurations with a sight hole. The blank tang affords installers flexibility for special drilling of mounting holes to meet certain requirements. SureCrimp connectors are made from high-grade copper, providing highly conductive, low heat connection. The seamless copper tubing provides improved connector endurance, and electro-tin plating offers protection against corrosion. All SureCrimp connectors are die stamped with wire size and die index number as well as part number identifier. Each lug is color-coded with permanent ink stamping for easy identification of proper die number and proper crimp positioning. SureCrimp connectors are UL listed and CSA certified for multiple conductor classes. Suitable for use in circuits rated 35KV or less.
Ilsco
For more information, visit www.ilsco.com.
Latest from Product of the Week
