Pin and sleeve devices
March 20, 2013
Designed to provide IP69K-rated protection, Arrow Hart pin and sleeve devices feature nickel-plated pins and contacts, individual silicone sealing grommets with cord diameter indicators, and threaded NPT cable entry.
Arrow Hart pin and sleeve devices offer IP69K-rated protection in demanding wet locations,
including those that require frequent washdowns. Featuring nickel-plated pins and contacts, the devices include individual silicone sealing grommets with cord diameter indicators, allowing users to quickly and easily select the appropriate grommet for their cable size. Additionally, the products include threaded NPT cable entry for an efficient means of attaching flexible conduit or wire mesh grips. Other features include Tri-Combo hardware that accepts a slotted, Phillips, or Robertson screwdriver as well as an inlet and receptacle mounting footprint that allows for interchangeability with many major brands.
Cooper Wiring Devices
For more information, visit www.cooperwiringdevices.com.
