The Wiremold OFR Series overfloor raceway system enables four channels of capacity and access to power, communications, and A/V connectivity.
Suitable for installations where access through floors and ceilings is not an option, the Wiremold OFR
Series overfloor raceway system provides four channels of capacity and access to power, communications, and A/V connectivity. Features include an in-wall entrance end fitting designed so that the raceway penetrates the wall through a flat, paintable plate. The feed fitting, configurable to one or two electrical channels, is hidden from view behind the wall. A tee/cross fitting allows the raceway to be branched to the left and right, while a removable twist-out creates a cross configuration that further extends the raceway. Additional features include an inside elbow that provides a transition up a step, riser, or onto a wall or table leg, while maintaining bend radius and complete protection of wires and cables.
