The Carlon retractable work surface receptacle features a 6-ft cord, a rotated orientation that accommodates oversized adapters, and a locking collar that secures the assembly to the work surface.
When not in use, the Carlon retractable receptacle can be recessed below a work surface by pushing
down on its cover. When access is needed, simply pull up the grip on its cover. An included hole saw attaches to a standard power drill and enables the product to be mounted quickly. A 6-ft cord that attaches to an existing outlet eliminates the need for wiring. Other features include a compact design, a rotated orientation that accommodates oversized adapters, and a locking collar that secures the assembly to the work surface.
