Bolted tee connector
Nov. 2, 2012
  Designed to accommodate cable diameters up to 800 mm2, the 36(42)kV bolted tee connector for is suitable for off-shore wind farm environments.
The 36(42)kV bolted tee connector for IEC-rated wind farm applications is
designed to meet higher voltage ratings and cable diameters up to 800 mm2. The fully-screened tee connector can be used for indoor and outdoor installations, and is suitable for harsh, off-shore wind farm environments. In addition, the 1,250A device features a pre-molded separable connector that allows users to quickly and easily connect polymeric cable to transformers, switchgear, motors, and other electrical equipment equipped with a “C” interface as specified by CENELEC EN 50180 and 50181.
Cooper Power Systems
For more information, visit www.cooperpowersystems.com.
