EZ Series In-Site CL Control Panel
May 9, 2012
The EZ Series In-Site CL control panel features a Modbus port located on the inside door to quickly connect to a Windows-based PC to download system events that have occurred
Designed to control one or two 120/208/240V single-phase pump(s) in water and sewage installations, the EZ Series In-Site CL control panel features a Modbus port located on the inside door to quickly connect to a Windows-based PC to download system
events that have occurred, including pump run times, pump cycles, alarm conditions, HOA settings, power outages, and service calls. The included In-Site software automatically formulates system data, up to 4,000 events, creating easy-to-read reports. In addition to data logging capabilities, the UL/cUL-listed product features a NEMA 4X weatherproof enclosure; lockable latch; audible/visual alarm; external alarm test/silence switch; auxiliary alarm relay; circuit breaker; transformer; pump run and tank level indicators; control and alarm power indicators; and a large terminal strip.
SJE-Rhombus
For more information, visit www.sjerhombus.com.
