Cord grips
July 11, 2012
The Bryant line of wiring devices now includes wire and cable grips, strain reliefs, support grips, and pull grips
The Bryant line of wiring devices now includes wire and cable grips, strain reliefs, support grips, and pull grips. Cord strain relief grips are designed to connect cable enclosures a
nd industrial equipment and prevent cable pullout at the point of termination. Deluxe strain relief grips, suitable for indoor and outdoor applications, are corrosion-resistant and feature endless stainless steel wire mesh weave to provide easy installation and arc-of-bend control. For indoor use only, dust-tight strain reliefs are constructed of galvanized steel mesh and are offered in models for use with cable diameters from 0.32 in. to 1.70 in. Standard duty support grips, for indoor and outdoor use, accommodate 0.54-in. to 1.74-in. cable diameter ranges, while light duty bus drop support grips are made of galvanized steel and attach to 0.24-in. to 1.25-in. cable diameter ranges. Galvanized steel low-tension pulling grips feature single weave variable mesh and are fitted with a flexible eye that easily attaches to pulling line snake or fish tape.
Automation Direct
For more information, visit www.automationdirect.com/strain-relief-grips.
