LED emergency luminaire
March 9, 2012
The EV LED Series emergency luminaire is designed for wall or ceiling commercial applications
The EV LED Series emergency luminaire is designed for wall or ceiling commercial applications. Requiring less than 2W to power, the luminaire measures 8.5 in. wide × 5 in. high with a depth of 2.75 in. The LEDs are mounted inside a die-cast housing that uses precision components to offer adjustability and thermal stability. Offering 90 min. of emergency illumination, the UL 924 damp location-listed luminaires feature a NiMH battery and accept 120/277VAC input at 60Hz and optional 220VAC to 240VAC input at 60Hz with a self-diagnostics option. Additional features include a micro-controlled pulse charger, optional LED remote, wire guard, and vandal-resistant shield.
Dual-Lite
For more information, visit www.dual-lite.com.
