The Sunnector solar connectivity product line includes whip and jumper assemblies, parallel circuit array harnesses, home run harnesses, and custom solutions
The Sunnector solar connectivity product line includes whip and jumper assemblies, parallel circuit array harnesses, home run harnesses, and custom solutions. The whip and jumper assemblies are pre-fabricated and designed to work with rigid and flexible thin-film, monocrystalline, and multicrystalline PV modules. The parallel circuit array harness assemblies feature a junction system that allows multiple arrays to be connected in parallel, while the home run – or sub-array – harnesses are designed for high current connection and power delivery to combiner boxes, sub-combiners, or inverters.
