For use with metal raceway, Steel TV 2- and 3-gang boxes allow flat screen televisions, furniture, and appliances to be mounted flush against a wall
For use with metal raceway, Steel TV 2- and 3-gang boxes allow flat screen televisions, furniture, and appliances to be mounted flush against a wall. According to the company, plugs and connectors stay inside the recessed box without extending past the wall. Suitable for new or retrofit applications, the UL- and CSA-listed products are nonmetallic and feature a white or black trim plate.
