The Met-Con connector is designed for use with the company’s PowerPlug 182S 2-pole luminaire disconnect
The Met-Con connector is designed for use with the company’s PowerPlug 182S 2-pole luminaire disconnect. Featuring a connector latch, this protective enclosure allows users to easily replace LED modules located in the air-handling space without the use of tools, according to the company. Made of zinc alloy and stainless steel, the product provides code compliance for use in spaces used for environmental air and complete metal enclosure for commercial lighting applications.
