Indicator luminaire
Nov. 7, 2011
The K50L Sealed Audible EZ-LIGHT is an easy-to-install indicator luminaire with an audible alarm
Suitable for use in areas prone to high moisture levels, the K50L Sealed Audible EZ-LIGHT is an easy-to-install indicator luminaire with an audible alarm. Featuring a fully sealed body that is IP67- or IP69K-rated, depending on the model, the luminaire includes a 12VDC to 30VDC operating range. In addition, the product is immune to EMI and RFI interference and is available in 1-, 2- and 3-color models with green, red, and yellow LEDs. Both the IP67 and IP69K models feature 5-pin Euro quick disconnect with PNP input, while the IP67 model also allows for manual volume adjustment.
Banner Engineering
For more information, visit www.bannerengineering.com.
